TwinTurbo.NET: Nissan 300ZX forum - switched my setup to NA as well...prefer it. (n/m)
Madhatter10-6
on March 28, 2016 at 10:41 AM
yes
posted by BarryGZX
on March 26, 2016 at 10:32 PM
Anyone deleted their clutch booster?
MaxxAction
21:44:45 03/26/16
yes
BarryGZX
22:32:23 03/26/16
Re: yes
MaxxAction
07:30:55 03/27/16
Bore size is the same
BarryGZX
13:27:55 03/27/16
NA master must be used w. NA pedal. (n/m)
21:14:23 03/27/16
switched my setup to NA as well...prefer it. (n/m) -
Madhatter10-6
10:41:36 03/28/16
Had similar issue. New MC & Slave, bled correctly
ttz'in (norcal)
02:23:30 03/27/16
Re: Had similar issue. New MC & Slave, bled correctly
BarryGZX
07:07:01 03/27/16
MaxxAction
07:32:21 03/27/16
You can check the booster for leaks @ the center piston. (n/m)
21:15:08 03/27/16
I'm not sure the problems you are having are related to the
Tanley (ATL)
09:56:05 03/27/16
Re: I'm not sure the problems you are having are related to the
aorqo
11:05:02 03/27/16
I highly doubt it's your booster
Stanky
13:52:39 03/27/16
Re: I highly doubt it's your booster
MaxxAction
17:52:01 03/27/16
MaxxAction
22:04:44 03/29/16
Pull the rubber boot off of the slave. Also inspect the rubb
06:30:21 03/30/16
Re: Pull the rubber boot off of the slave. Also inspect the rubb
MaxxAction
13:32:49 03/30/16
Are you using speed bleeders? (n/m)
Tanley (ATL)
06:40:01 03/30/16
Re: Are you using speed bleeders?
MaxxAction
13:31:44 03/30/16
Not suggesting them, just wanted to know if you were using
Tanley (ATL)
18:01:24 03/30/16
Re: Anyone deleted their clutch booster?
MaxxAction
20:14:46 03/30/16
